How do I use this printer to print an envelop
Nstructions
Use the following steps to ensure that you are ready to print envelopes.
Your printer can have either a single envelope or multiple envelopes loaded and ready for printing.
To Load a Single Envelope
To Load Multiple Envelopes
NOTE:
To minimize print skew, use envelopes with rectangular flaps rather than triangular flaps.
Set up the Printer Properties
Print
Print the envelope from your chosen program. From most applications, just select the File menu, then choose Print.
After Printing the Envelopes
Reset the printer and the printer properties for the kind of printing you will be doing next.
SOURCE: Printer Error When Printing Envelopes
I had problems printing 4 X 6, and found out that I needed to go into the printer mode, and change the tray feed from "main tray" to photo tray. Try that one.
SOURCE: CANNOT PRINT ENVELOPES
i just wont be using the printer for printing envelopes. I have a problem with having to pay for support on any product.
Printing an
Envelope
For details about how to load an envelope into the printer, see
the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear
tray, orient the envelope so that the flap is on the left and the folded surface
is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the
Main tab.
4. Click the Page
Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape
for Orientation.
6. Click OK.
When you execute print, the information is printed on the
envelope.
Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes.
Printing envelopes from the envelope feeder
