This is from the nintendo website:
Likely causes: Your Internet connection has slowed or was interrupted, or our servers could be busy.
to find possible information to help you get your connection back go to http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=32002&system=Wii&locale=lang
If you get an error code of 32002 on you Wii console, this indicates a problem with your Wii communicating with your wireless router.
There are a couple things you can try/check to help fix this problem:
1.Try using a different channel on your router and update your Wii to take to the router on that channel.
2.If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
3.Make sure the MTU values on your router match those entered on your Wii.
Also note that if you make changes to your wireless router and you have a computer that uses that router too, you'll need to update your computer to match the new settings on your router.
