20 Most Recent Foxconn 661MX Motherboard Questions & Answers
3answers
Foxconn 661mx plus
blue screens means you have problems with your operative system or memory so make sure your operative system cd is in good coditions and reinstall it
3/10/2019 4:27:23 PM • Foxconn 661MX... • Answered on Mar 10, 2019
Sound not working on Foxconn 661MX motherboard!
Hi See if you can flash the bois upgrade on the website. It sometimes fixes such issues. Chadman
11/18/2014 5:10:07 AM • Foxconn 661MX... • Answered on Nov 18, 2014
H foxconn awrdacpi video
Hello you can download the driver here:http://www.foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000099If not the right product find the mainboard elsewhere on the foxconn site.Good luck
10/30/2012 12:37:03 PM • Foxconn 661MX... • Answered on Oct 30, 2012
Mouse can not move
make sure the lead is securely seated or the batteries have charge and are secure also the usb device is secure in the usb port or you could restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
if you need any further help with this post a reply
hope this helps
8/3/2011 8:04:22 PM • Foxconn 661MX... • Answered on Aug 03, 2011
3answers
I have a 661mxplus 478
Here is the intel site to driver update utilities your motherboard or search there
http://downloadcenter.intel.com/Default.aspx
Here is the Foxconn site with two drivers 661mx and pro
http://www.nodevice.com/search/search.html?text=661MX&search_area=all
2/18/2011 1:20:09 PM • Foxconn 661MX... • Answered on Feb 18, 2011
Have ecs 648fx a mb and video has stopped
Welcome to fixya
I have a solution for this
Content
Please reinstall your operating system and all motherboard device drivers. Once you have done so, your problem should be fixed. There is no reason why both the onboard and expansion card drivers can not be detected by the operating system and thus providing you with video.
Your pre-solution is located above. More information is available in the comments
My name is Bruce
1/20/2011 8:07:20 PM • Foxconn 661MX... • Answered on Jan 20, 2011
2answers
Cannot get any sound from pc
Did u install the sound drivers
9/6/2010 8:04:15 AM • Foxconn 661MX... • Answered on Sep 06, 2010
I need the board schematics as to where the cables
Go here;
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000114
6/16/2010 11:38:01 PM • Foxconn 661MX... • Answered on Jun 16, 2010
Where can I get my Cnmbook repaired.
if it is just the power plug ..this can be easy replaced ..but if it is something on the motherboard that affect the power stream .that is much complicated and you will need to get it to a repair shop ..anyway the power plug is attached to the mother board and you can get one on the internet and than just see if yo can change it yourself ..(it has a few welding points on the back side)..if not just go to any electronics repair shop near by cause the operation itself is not that sensitive ..They can also see if the issue is from other cause by using a measurement tool ..anyway ..to locate the plug exactly you will have to see its serial ..but they are kinda universal ..usually they run on PJ10 plugs..and if you see this name it they are available on ebay for a about 1 dollar..
5/23/2010 6:12:12 PM • Foxconn 661MX... • Answered on May 23, 2010
Witch is the highest cpu this mother will take
Here is a link to the list of compatible CPU's for your MB:
http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&socket=Socket%20478&model=661MX&cputype=Intel
Looks like a P4 2.8GHz w/533FSB (Northwood or Prescott) or 2.8GHz Celeron.
Thanks for using Fixya.
Note: The link above may give you a "Network Busy" notice. If it does keep trying. Took me a while to get to it.
10/10/2009 4:14:11 AM • Foxconn 661MX... • Answered on Oct 10, 2009
Can I connect as a slave a ATA hard drive?
Yes
7/13/2009 5:00:30 PM • Foxconn 661MX... • Answered on Jul 13, 2009
My computer hanging in on candtion
There are probably 2 problems 1 is your processor fan is not working fine, 2nd is ram problem and 3rd is problem is in the main board condenser
11/14/2008 12:30:45 PM • Foxconn 661MX... • Answered on Nov 14, 2008
2answers
Motherboard
Hi michlionfan, the following link shows what CPU's your Foxconn 661MX board can handel.
http://www.foxconnchannel.com/Upload/Compatibility/200607120855293005661MXhtm.htm
Link to foxconn 661MX motherboard site.
http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000114
From this site, look to the left & find the words, Main Page typed in green. Under these two words is, compatibility. Click on it.
Best wishes!
If you need any more help feel free to post here or click the ask me button.
Mike
11/8/2008 5:56:03 PM • Foxconn 661MX... • Answered on Nov 08, 2008
Memory question
yes, 100% correct ram for that board.
please vote if this helps.
9/5/2008 4:56:07 AM • Foxconn 661MX... • Answered on Sep 05, 2008
Need help
Do you have all the power supply cords fitted into M/board
M/boards nowadays have 1 large white plug and sometimes 1 smaller 4 pin one or an 8 pin one
Does your power supply have them if not you will have to upgrade tou power suplpy
8/15/2008 6:27:51 AM • Foxconn 661MX... • Answered on Aug 15, 2008
CPU throttles for No Reason!
Turbo-Cool makes a better power supply then all the rest . For total happiness even if you use two PCI-16 video cards ( CrossFire Ready, SLI Ready ) Turbo Cool 860-Watt Power Supply .
8/12/2008 4:52:04 AM • Foxconn 661MX... • Answered on Aug 12, 2008
Cannot Install Windows
Well it sure sounds like an overheating problem, and 77 degrees celcius is way too high, specialy if it's right after boot! try reseatting the heatsink and make sure the repair place put a thin coat of heatsink compound paste on the processor. You need to bring that number down so really pay extra attention to the heatsink.
The next thing would be a bad memory module check out http://www.cas411.com/ShowArticle.aspx?ID=66 , it talks about surprising behaviors of PCs when a memory goes bad.
Hope this helps!
Alex J.
4/4/2008 7:34:46 PM • Foxconn 661MX... • Answered on Apr 04, 2008
It won't Post ! ! ! !
I suspect Mother or Ram may have been failed try changing Power supply. If not Try on other mother board.
Best Regards
Rafique
2/10/2008 7:02:02 PM • Foxconn 661MX... • Answered on Feb 10, 2008
Foxconn 661MX Motherboard Logo
30 questions posted
Top Foxconn Computers & Internet Experts
Rommel Balcita
Sudeep Chatterjee
Sudeep Chatterjee
Darran Hatten
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Foxconn Computers & Internet
Most Popular Question
h foxconn awrdacpi video
  • Computers & Internet
